Not Charging
Was given MacBook Pro (Retina, 13-inch, Early 2015). The charger had been dropped in saltwater and replaced with new magsafe 2 power adapter model A1435. No lights come on when it is connected to the MacBook. The MacBook does not turn on. I understand the battery could be bad, or the SMC needs to be reset but want a good source of info before I did into this machine.
My neighbor bought a new MacBook and had the contents of the drive moved to the new MacBook. I do not know if things were copied over or if the drive was wiped.
How to check the new MagSafe adapter itself? What voltages should I expect from it, and which pins?
-Is the new adapter an Apple OEM part?
-Have you tried flipping the MagSafe adapter over and connecting it?
-Here are the two resets you can try: SMC and NVRAM.
Since Apple doesn't publish schematics, I am not sure what voltages you would get by testing with a meter...sorry. If the SMC reset doesn't fix the issue, then it is either a faulty MagSafe adapter or I/O board/logic board issue with the MBP.
Yes, Brand new from the Apple Store. It is the correct model.
Yes. Looking at the MagSafe port (correct terminology?) on the MacBook itself there are 5 contacts. The 2 on either side of the center one looked very dirty, maybe burned. I burnished them. Still no luck. I am going to first disconnect the battery, connect the power adapter to see if the Book boots. If not I will replace the MagSafe port and try again. No way to disconnect the RAM. That did work on an iMac - no chime, black screen.
Tried those to no avail.
