My MacBook's Pro 15" display is flickering
Hello there,
I have a MacBook Pro 15" 2017 and I have this weird flickering that is happening all the time.
I went to the repair store and they are in doubt of what might be the problem.
- Have you experienced similar issues?
- What would be your guess of what's wrong?
- How much would it cost to get fixed?
Normally, that is a loose video cable connection, failing LCD assembly, or a logic board issue. Cost would is variable depending on what the actual issue is.
I assume it is out of warranty since you inquired. Did you take it to an Apple Authorized Service Provider, or a standard computer repair shop?
