IMac problem starting
I have been hearing a faint clicking sound the past few days while using the computer, sounded like a hard drive. This morning when I went to restart, it failed to start up. I got this screen upon restart to white screen. Any help would be much appreciated. Thank you
That is a kernel panic, which can be caused by software issues or hardware failures.
  • From your image, it looks like you are using an iMac (21.5-inch, Mid 2010), correct?
  • Which version of OS X/macOS?
  • Was the click sound constant or intermittent?
  • Were you experiencing any hanging/freezing or other issues?
