Early 2008 iMac 24" PCB Liteon/Delta compatability
I have an early 2008 iMac (A1225 (EMC 2211) IMac8,1 24") Ser Nbr VM 8220 RUZE7 with a dead PCB. The original is a Liteon, Ref 8202A8QC Rev 0H, whilst the replacement is a Delta, Ref 614-0416.
Unfortunately, the very small connectors (I think it is from the temperature sensor) are different.
I was previously sent an early 2009 PCB in error, the connector on that is the same as the Liteon.
Has anybody come across this problem, if so how solved?
I assume you are referring to the power supply? If the connectors are different, then it sounds like it is the incorrect part. Apple did use both Liteon and Delta parts in those iMacs, and they had the same connectors.
Where did you get the Delta replacement?
