Using iPad as whiteboard on Zoom
I have an older iPad Pro IOS 9.3.5 - I'd like to use it as a whiteboard when teaching via Zoom. Is it compatible with an Apple or other stylus?
Thanks for your help.
I assume you mean an iPad Pro (12.9-inch, Wi-Fi) or iPad Pro (9.7-inch, Wi-Fi)? All iPad Pros support the Apple Pencil, which was released with the original iPad Pro models (available separately). The current Apple Pencil 2 isn't supported by the 9.7-inch iPad Pro however, so you'd need to find the original Apple Pencil. There are other styli that will work, but in a very basic mode.
Hope that helps,
