Preview problems
Hi
I'm having trouble with "Preview" everytime I open the application it won't load and I get the application not responding message.
I'v tried preferential treatment but everything seems ok.
Any ideas on what may be causing it to not work?
Thanks in advance
Will have a think later, in the interim try and delete the preference file;
You can find it here: Users/'Danster'/Library/Preferences/com.apple.Preview.plist.
Delete "com.apple.Preview.plist."
Then reboot and try again, Preview should then generate a new preference file.
Problem solved
I searched the HD by typing "preview" into the search criteria and found the preferences, threw it into the trash and now it works like magic. :D
