- Dec 18, 2021
Good morning! I'm trying to put together a quick list of ways to troubleshoot various MacOS issues and then prioritize them in the order that we should try first, since time is of the essence. Naturally, this would be better determined by Mac system admins with way more experience than me. This is what I have so far, can anyone help add to the list or tell me what I should move up or down based on your experience with what works best/most often? Thank you so much!
Run First Aid
Use Apple Diagnostics
Remove recent software/plugins, etc.
Disconnect all devices, add back one at a time
Remove questionable software (uncertified, third parties, beta, etc.)
Disable unnecessary startup items
Update OS
Free up disk space
Reset disk permissions
Check File System ("/bin/fsck -fly")
Force Restart and reset PRAM
Login issue – reset NVRAM and PRAM
Reinstall the MacOS
Run First Aid
Update OS
Free up disk space
Reinstall the MacOS
