- May 19, 2004
-What do you mean by unreadable - blank, distorted, etc? Can you upload a photo of what the screen looks like?
-Do you have an external monitor you can connect? If so, does it have the same issue?
We don't recommend heating the Mac up in that manner as you can easily cause damage to the chips/components. It sounds like either the display itself or the video section of the MLB has failed.
