SOLVED Help in Find an iPad for me
I need help in picking the right iPad for me.
Uses:
- Note writing/studying
- I use notability
- I need more space than my current iPad (32 GB)
Not Using For:
- I do not game
- I do not listen to music
- Rare use it for YouTube
Background:
- I have a 5th Gen iPad that I currently use. It is hard to write with a cheapo stylus because the palm rejection lags on the iPad while using Notability. I have to wear a THICK sock on my right hand to cover my palm and knuckles so they don't touch the screen. The newer smart stylus do not work with my older iPad.
- My current 32 GB iPad needs more space! I had to delete my old notes and store them online, which means I can't use them in Notability. I would like a larger storage so I can keep all my school notes on it.
Budget:
- The cheaper the better.
- I am willing to buy USED, I'm just not sure if a used iPad would be better than the Black Friday deals.
- Because I write so much, a bigger screen would be nice, but I don't want to pay an arm and a leg for a PRO since I don't do anything else other than write and study with Notability.
- Storage is important because I like accessing my older school notes. 32 GB is not enough.
Thank you!
Sorry we didn't respond until now. This is marked as resolved - did you still need advice?
