- Jan 16, 2018
So, my screen is currently showing a bouncing lightening bolt inside of a circle, as well as a battery at the bottom of the screen. Its a gray screen. I believe I may have pressed the T key and entered target disk mode. I should note that I'm not connected to any other computer. Anyway, I tried to hold down the power button, I tried pressing control-option-command-power, command-option-escape, command-option-p-r. Nothing is working.
The battery is almost dead. Should I just wait for the computer to die, plug it in and restart? How else can I get out of here..
Thanks for the help
Thanks for the help
