After memory upgrade power mac will not start
Can anybody help with this issue!
Power mac G5 will not start up after memory upgrade.
I press the power button, hear 2 beeps and fans kick in at full speed, and the there is not further activity.
I have been reading threads on this, and i cannot restart because i am not using using a mac key board, just normal windows qweryty keyboard.
I have also tried to locate the reset button on the chipboard, but i cannot find it.
Power Mac G5, 1.8 single , running on os x leopard
Remove the memory you installed and re-boot your Mac. If it works, then you'll know the memory you installed is bad.
Thnaks Egidio for your posting.
I have solved the problem - it was that i had installed only one unit of the memory, were as the mac install memory by pairs! - so i put another unit to make it into a pair and it started working.
thanks any way
