- Dec 11, 2021
After extensive searches I cannot find a cable like this. I can find every other type of cable except this one.
I need to work with film files on the Mercury Pro. The data disc is 100GB. I can connect from Mercury Pro using the cable that came with
the burner - which is a standard USB cable. However the film splutters when I view on MacBook Pro 2014. Adobe said that I needed to use
Thunderbolt connection to be able to play the films without splutters, loss of audio. Is there such a cable ? or an adapter? Let me know !
Thanks
Thanks
