Screen problem - Black Bars & "Freezing" window bars on top of screen
Hi all,
I have an issue as lately my Macbook Pro 2017 13.3 (currently running on Catalina) is showing some bad signs.
The screen at the very top has a black horizontal line, along with deteriorated graphics from the all different windows that were open (see images).
While I took a screenshot, the lines do not appear on the photo; hence making it most likely a screen problem I presume.
I also have a cooler underneath it and I'm really surprised should it be a temperature damage.
Anyone having prior experience with this?
Thanks!
That looks like a graphics/logic board or display panel issue. You are correct that a screenshot will not capture it, since it is a hardware, not software issue.
You can test it to see which it is by connecting an external display. If the issue persists, then it is a graphics/logic board issue. If not, then it is a display panel issue.
Do you have an external display to connect it to?
Hello Cory,
Thanks for your answer.
Indeed, I have connected another monitor as a 2nd one, and the problem appears only on my macbook.
OK, thanks.
It sounds like a display panel issue then, and will probably require a hardware repair.
