Open Applications - Help
Hi I am trying to Open several applications I use every day and have them open full screen in a new space. Below I will show you my code in automator but for some reason it never works for all the applications. Maybe they are opening to fast to accept the control command F to go full screen ? If there is a better way to open applications full screen so I don't have to open each ap myself that would be great.
- some of the apps open but do not go full screen, even though they are able to manually.
Here is my code:
on run {input, parameters}
tell application "Komodo Edit"
activate
end tell
delay 2
tell application "Google Chrome"
activate
tell application "System Events"
tell process "Google Chrome"
delay 1
keystroke "f" using {command down, control down}
end tell
end tell
end tell
delay 2
tell application "Safari"
activate
tell process "Safari"
delay 1
end tell
end tell
end tell
delay 2
tell application "Mail"
activate
tell process "Mail"
delay 1
end tell
end tell
end tell
delay 2
tell application "Terminal"
activate
tell process "Terminal"
delay 1
end tell
end tell
end tell
delay 2
tell application "TweetDeck"
activate
tell process "TweetDeck"
delay 1
end tell
end tell
end tell
delay 2
tell application "iTunes"
activate
tell process "iTunes"
delay 1
end tell
end tell
end tell
delay 2
tell application "Skype"
activate
tell process "Skype"
delay 1
end tell
end tell
end tell
delay 2
return input
end run
Back
