iPhoto HELP PLEASE!!!
I am new to this forum here so hopefully I have posted this in the right place. Ok, I have been reading numerous discussions on iPhoto problems. After trying everything suggested by other people, I am still stumped. By everything, I am referring to trying to rebuild iPhoto library, download iPhoto Library manager, re-install iPhoto (and made sure receipts were deleted before doing this), booting in safe mode, checking the color profiles since that looks to be an issue, and going through the whole Disk Utility stuff. I am by no means experienced in working with Apple since I am new to Apple products. Any help would be great by anyone. Below is a recent crash report and just a few lines. Thanks in advance!
Process: iPhoto [677]
Path: /Applications/iPhoto.app/Contents/MacOS/iPhoto
Identifier: com.apple.iPhoto
Version: 9.4.2 (9.4.2)
Build Info: iPhotoProject-710042000000000~2
App Item ID: 408981381
App External ID: 11723545
Code Type: X86 (Native)
Parent Process: launchd [146]
User ID: 501
Date/Time: 2013-04-07 11:15:36.005 -0400
OS Version: Mac OS X 10.8.3 (12D78)
Report Version: 10
Interval Since Last Report: 60975 sec
Crashes Since Last Report: 6
Per-App Interval Since Last Report: 135 sec
Per-App Crashes Since Last Report: -20
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000024
VM Regions Near 0x24:
--> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] ---/--- SM=NUL /Applications/iPhoto.app/Contents/MacOS/iPhoto
VM_ALLOCATE 0000000000001000-0000000000055000 [ 336K] ---/--- SM=NUL
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.apple.CoreGraphics 0x9678ec6c color_space_create_adobe_rgb_1998 + 28
1 com.apple.CoreGraphics 0x9666dd70 CGColorSpaceCreateAdobeRGB1998 + 32
2 com.apple.CoreGraphics 0x9642b46b CGColorSpaceCreateWithName + 652
3 com.apple.geode 0x01079d4a +[DGColorSpace initialize] + 1018
4 libobjc.A.dylib 0x90267600 _class_initialize + 305
5 libobjc.A.dylib 0x902674c8 prepareForMethodLookup + 78
6 libobjc.A.dylib 0x90267337 lookUpMethod + 81
7 libobjc.A.dylib 0x902672e1 _class_lookupMethodAndLoadCache3 + 47
8 libobjc.A.dylib 0x90266ac1 objc_msgSend + 81
9 com.apple.geode 0x010798a0 +[DGContextMgr newBitmapContextCached:accelerated:] + 61
10 com.apple.geode 0x0107985e +[DGContextMgr newBitmapContextWithAcceleration:] + 49
11 com.apple.RedRock 0x02647bf6 -[Godot loadGeode] + 1261
12 com.apple.RedRock 0x026448a8 -[Godot init] + 1571
13 com.apple.RedRock 0x026437d2 +[Godot initGodotApp] + 108
14 com.apple.iPhoto 0x00083be8 0x55000 + 191464
15 com.apple.iPhoto 0x0008236b 0x55000 + 185195
16 com.apple.Foundation 0x9a3bc4cf __NSFireDelayedPerform + 413
17 com.apple.CoreFoundation 0x95ed1416 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 22
18 com.apple.CoreFoundation 0x95ed0db5 __CFRunLoopDoTimer + 709
19 com.apple.CoreFoundation 0x95eb5bc2 __CFRunLoopRun + 1842
20 com.apple.CoreFoundation 0x95eb502a CFRunLoopRunSpecific + 378
21 com.apple.CoreFoundation 0x95eb4e9b CFRunLoopRunInMode + 123
22 com.apple.HIToolbox 0x9052af5a RunCurrentEventLoopInMode + 242
23 com.apple.HIToolbox 0x9052abf5 ReceiveNextEventCommon + 162
24 com.apple.HIToolbox 0x9052ab44 BlockUntilNextEventMatchingListInMode + 88
25 com.apple.AppKit 0x923c39aa _DPSNextEvent + 724
26 com.apple.AppKit 0x923c31dc -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 119
27 com.apple.AppKit 0x923b963c -[NSApplication run] + 855
28 com.apple.AppKit 0x9235c666 NSApplicationMain + 1053
29 com.apple.iPhoto 0x00064c99 0x55000 + 64665
30 com.apple.iPhoto 0x000642e5 0x55000 + 62181
VM Region Summary:
ReadOnly portion of Libraries: Total=246.0M resident=144.9M(59%) swapped_out_or_unallocated=101.1M(41%)
Writable regions: Total=169.5M written=22.7M(13%) resident=37.4M(22%) swapped_out=0K(0%) unallocated=132.1M(78%)
REGION TYPE VIRTUAL
ATS (font support) 32.0M
CG backing stores 6040K
CG image 112K
CG raster data 236K
CG shared images 1184K
CoreImage 4K
CoreServices 1616K
MALLOC 74.8M
MALLOC guard page 48K
Memory tag=240 4K
Memory tag=242 12K
Memory tag=249 156K
Memory tag=35 3696K
OpenCL 20K
SQLite page cache 768K
Stack 86.1M
VM_ALLOCATE 18.8M
__DATA 10.7M
__DATA/__OBJC 304K
__IMAGE 528K
__IMPORT 16K
__LINKEDIT 48.5M
__OBJC 6256K
__OBJC/__DATA 4K
__PAGEZERO 4K
__TEXT 197.5M
__UNICODE 544K
mapped file 235.2M
shared memory 372K
TOTAL 725.1M
Model: MacBookPro8,1, BootROM MBP81.0047.B27, 2 processors, Intel Core i5, 2.4 GHz, 8 GB, SMC 1.68f99
Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 512 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353237334348302D4348392020
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353237334348302D4348392020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 (5.106.98.100.16)
Bluetooth: Version 4.1.3f3 11349, 2 service, 11 devices, 3 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: TOSHIBA MK5065GSXF, 500.11 GB
Serial ATA Device: HL-DT-ST DVDRW GS31N
USB Device: hub_device, 0x0424 (SMSC), 0x2513, 0xfa100000 / 3
USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0252, 0xfa120000 / 5
USB Device: BRCM2070 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000 / 4
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x821a, 0xfa113000 / 7
USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x8509, 0xfa200000 / 2
USB Device: hub_device, 0x0424 (SMSC), 0x2513, 0xfd100000 / 2
USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd110000 / 3
iPhoto '11, OS X Mountain Lion (10.8.3)
Sounds to me like you have a corrupt photo in your Library.
To check this
Start iPhoto with the Option Key help down.
Create a New Library with a good name, like New Blank Library, so you can delete it later if needs be.
Does iPhoto still crash using this Library? Add some photos, quit and go back in? all good?
Hey thanks for the response. Yeah it was still crashing even when trying to rebuild or create a new library. I was able to fix iPhoto but had to do a reinstall by using the Command-R at start up. I posted a rather lengthy discussion on the Apple Support Communities page. And for anyone who is experiencing the same of similar issues to what I was going through with iPhoto, here is a link to the steps I took to fix the problem.
https://discussions.apple.com/thread/4960062
