How to Block Temu.com Ads on iPhone: Full Guide
Are you tired of constant interruptions from Temu.com ads on your iPhone? This article will help you block annoying ads and enjoy a smoother browsing experience.
How to Block Temu.com Ads on your iPhone:​
1. Disable Personalized Ads​
  1. Go to "Settings" on your iPhone.
  2. Scroll down and tap on "Privacy."
  3. Select "Apple Advertising."
  4. Toggle off "Personalized Ads."
This action prevents your device from using your browsing and app usage history to show targeted ads, such as those from Temu.
2. Use Safari’s Built-In Ad Blocker​
  1. Open "Settings" on your iPhone.
  2. Scroll down and select "Safari."
  3. Toggle on the option for "Block Pop-ups."
Activating this feature will help you see fewer pop-up ads in Safari, making your browsing cleaner.
3. Install Third-Party Ad-Blocker Apps​
Consider downloading reputable ad-blocker apps like AdGuard or Adblock Plus from the App Store to significantly cut down the number of ads you see across websites and apps.
4. Block Pop-ups on Google Chrome​
  1. Open the Google Chrome app on your device.
  2. Tap on "More" (three dots) at the bottom right.
  3. Select "Settings" and navigate to "Content Settings."
  4. Choose "Block pop-ups" and toggle the switch to enable.
Enabling this setting will minimize the interruptions from pop-up ads, including those from Temu, enhancing your browsing experience.
By implementing these solutions, you can significantly reduce the presence of Temu.com ads and other intrusive advertisements on your iPhone, leading to a more enjoyable online experience.
Didn’t work on my iPhone 13
Temu still sending annoying ads and I only looked up Temu to see who they were. Never ordered a thing
