File sorting replacing problem
I am have made a folder action. It works in for the most part but where I am having a problem is it will not replace the file once it aready exists.
What I am tring to do is but files in alphabetitcal order based on the first letter of the file. and but it in the subfolder.
also if anyone can stream line this any better I am all ears. I have tried different replace commands I could come up with but it did not work.
Any help anyone could give I would be thankful
This is the Code that work with out the replacing function
tell application "System Events"
set these_files to every file of folder "Volumes:Member Pics"
repeat with i from 1 to number of items in the these_files
set this_item to item i of the these_files
set this_info to info for this_item
if visible of this_info is true then
set file_name to name of the this_item
set the first_char to (character 1 of the file_name) as string
beep 1
display dialog first_char buttons {"OK"} default button 1
if first_char is "a" then
move this_item to ":Volumes:Member Pics:a"
else if first_char is "b" then
move this_item to ":Volumes:Member Pics:b"
else if first_char is "c" then
move this_item to ":Volumes:Member Pics:c"
else if first_char is "d" then
move this_item to ":Volumes:Member Pics:d"
else if first_char is "e" then
move this_item to ":Volumes:Member Pics:e"
else if first_char is "f" then
move this_item to ":Volumes:Member Pics:f"
else if first_char is "g" then
move this_item to ":Volumes:Member Pics:g"
else if first_char is "h" then
move this_item to ":Volumes:Member Pics:h"
else if first_char is "i" then
move this_item to ":Volumes:Member Pics:i"
else if first_char is "j" then
move this_item to ":Volumes:Member Pics:j"
else if first_char is "k" then
move this_item to ":Volumes:Member Pics:k"
else if first_char is "l" then
move this_item to ":Volumes:Member Pics:l"
else if first_char is "m" then
move this_item to ":Volumes:Member Pics:m"
else if first_char is "n" then
move this_item to ":Volumes:Member Pics:n"
else if first_char is "o" then
move this_item to ":Volumes:Member Pics:eek:"
else if first_char is "p" then
move this_item to ":Volumes:Member Pics:p"
else if first_char is "q" then
move this_item to ":Volumes:Member Pics:q"
else if first_char is "r" then
move this_item to ":Volumes:Member Pics:r"
else if first_char is "s" then
move this_item to ":Volumes:Member Pics:s"
else if first_char is "t" then
move this_item to ":Volumes:Member Pics:t"
else if first_char is "u" then
move this_item to ":Volumes:Member Pics:u"
else if first_char is "v" then
move this_item to ":Volumes:Member Pics:v"
else if first_char is "w" then
move this_item to ":Volumes:Member Pics:w"
else if first_char is "x" then
move this_item to ":Volumes:Member Pics:x"
else if first_char is "y" then
move this_item to ":Volumes:Member Pics:y"
else if first_char is "z" then
move this_item to ":Volumes:Member Pics:z"
end if
end if
end repeat
end tell
Hi LightGear and welcome...
try this...
change tell application "System Events"
to tell application "Finder"
then on each line that says...
change it to...
move this_item to ":Volumes:Member Pics:z" replacing yes
give that a go !
It can be quite tricky to 'know' when to use "System Events" instead of "Finder"...
...the best advice I can give is to look in the Dictionaries of each, ( Script Editor-->Open Dictionary-->Select the App) if you look in "System Events' dictionary there is no 'replacing' whereas in the 'Finder' dictionary there is...
If in doubt have a look...
sleep
end tell
sleep
end tell
both do the same thing !
Thanks RIC I will give it a shot. Also is there a better way to write this code.
Say like this...
I get the first letter of this_item and move it to a folder with the same letter. :D
I am not sure if this is possible but if it is, I would be able to make the code a lot shorter
Thanks again for the help :)
No problem...
I'll have a think about how you could make the code smaller/neater...but sometimes if it does what you want then it's best to leave as is, as long as it works !
The idea is that the AppleScript should save you time ;-) Not create more problems for you...
...I know what you mean though !
