- Apr 8, 2022
OSX Ventura. 13.4
Two systems (part of a larger network)
* Both systems are in the same room.
* The Server has 2 Thunderbolt RAIDS attached to it. (The raids are 100% fast enough to saturate 1GigE. )
* Sharing is on.
* WIFI + 1GigE are active on both
* BUT I want these systems to talk via A TB 3 cable +(TB Bridge) for throughput.
* Service order is Bridge > 1Gig > Wifi.
* The network addresses are 10.0.1.X - except for the Tbolt Bridge.
When I connect up the TBolt Bridge, it shows a Self-assigned IP.
Which means it changes on every reboot of the server.
How can I make this so the IP of the Bridge is fixed?
* Sharing is on.
