Wifi signal boost help
My new wifi router seems a bit weak..
Its an NBN standard peace so no surprise...
I have one room that gets poor signal quality though there is a n ethernet port in that room but its nice not to be tethered.
Is there a reliable quality product i can plug into that ethernet port to make good the wifi in that area ?
NBN is the Australian National Broadband Network, correct?
Wi-Fi signal strength can be affected by numerous things: distance, Wi-Fi router capabilities, structure materials, etc. Depending on the router you have, you may be able to either relocate it more centrally or possibly add a Wi-Fi extender.
What brand/model is the router, and do you have access to its configuration settings?
Hi and thank you Cory.
Yes NBN is what you say and will be the only network available in Australia soon which is a step backwards for many like me.
My router is in a cupboard next to my patch panel which takes ethernet ports to all rooms.
There is just one room that seems to get a poor signal.
I was hoping there would be a device that i could plug into the ethernet port in that room that would make good the signal.
No worries.
I wonder if part of your Wi-Fi signal is getting blocked by having the router in a cupboard. I have definitely seen issues when routers are not out in the open, and are partially/fully blocked by cabinetry. Maybe try running it outside the cupboard and see if that helps.
You may be able to add an extender or even another small Wi-Fi device in the other room. But, it can sometimes be a bit tricky, depending on the main router.
I don't know if other countries have this but in the UK there is a master socket.
Its where the broadband enters your house and if your router is connected by the master socket apposed to another socket it can make a big difference. In my case 14 Mbps.
I don't know much about networking but I just thought I'd share what I know.
