Using a laptop as an external display, keyboard and mouse
I have a MacBook (on Tiger) that I would like to use as an external display, mouse and keyboard for my Mac Pro (also on Tiger).
Edit: I feel I should add: I meant as the sole and primary display.
TIA,
Prez
Hello President and Welcome.
Sorry I missed these posts.
To answer your first post, I am not sure if there is a way to do that or not.
But, there is a solution for your third post. Take a look at the ModBook, a Tablet Mac with some cool features.
http://www.axiotron.com/
Also check out the article about the ModBook on MacWorld.
I hope this helps you!
Cheerio
Searay
To answer your first post: It is possible, but the responding time would freak you out. I mean the time from you move your mouse until you see it move on the screen. As of today I don't know any apps that might do what you want.
Thank you quadra and searay.
I've already seen the ModBook. My problem is I have a slow MacBook and a lightning-fast Mac Pro. The Mac Pro I barely use and I want the power on my laptop. I don't want to buy a MacBook Pro though. Is there an external display that I can put on my lap?
Thanks.
Thanks.
I'm not entirely sure whether this will do everything you need, but Screen Recycler looks like it might help. It has a free trial so you're not risking nay money trying it out. Looks like you'd probably be able to use it so that you would use your laptop as a screen and plug everything else into the MP.
Hope that's some help.
J
