Trouble with Java Script
I have an iPad mini 4 and I use a particular website quite a lot on my iMac and old iPad and want to use it on my new mini when I’m out and about. However it doesn’t seem to work and keeps coming up with 'you currently have Java Script disabled on your web browser' I definitely haven’t even when I follow the instructions on how to 'enable' it that link tells me that it is enabled.
Can anyone advise me what to do please?
I'd be happy to test the site out on my iPads to see if I get the same issue. I would guess it is more to do with the website than your iPad, especially if you don't have issues on others.
Which version of iOS are you running?
Try this: Enable JavaScript in Safari on iPad. Make sure you click on the link in Step 7 at the bottom of the article to test it: "Congratulations, you just enabled JavaScript. Tap here to confirm that JavaScript is now enabled."
