Surreal sound
Not sure what you mean by "honking"?
-Which model Mac?
-Can you describe the sound further?
-Does it make the sound when using certain applications?
iMac
It really sounds like a honking goose.
Sound is intermittent - when I'm using the keyboard on any app. ???
Could it be one of the  > System Preferences... > Sound > Sound Effects > alert sounds? If so, you could have a bad key on your keyboard, which may cause the alert to play when it is pressed.
Yes, it was the basso sound. I pressed all the keys and some did honk - then didn't honk and others honked. My keyboard is fully charged. Do need another one?
Ahhh...glad you found the source.
You don't need a new keyboard necessarily. Some keys don't work in some apps.
-Are the ones that honk consistent in all apps?
-Which keys give the alert sound?
I tried a different keyboard with the same results. Because my mouse was also acting strangely, I used the disk utility from the safe boot. It partially helped, so I downloaded ClamXAV and it seemed to clear up the situation. Perhaps, I had a virus. Thanks again. (*_*)
