Running a program that needs Classic on a MacBook Pro. Possible?
Hello -
I would like to use the software "International Inspirer," which uses Classic, in my classroom on my MacBook Pro, which uses OS 10.7.5. Is there any way to support something which uses Classic? If need be, I can drag the eMac out of the shed and use it . . . would prefer not to. Thank you!
Classic was available on PowerPC Macs through 10.4 Tiger.
Rosetta was available on Intel Macs through 10.6 Snow Leopard, although you had to do a custom install in 10.6.
In this case, I would drag the eMac out and run International Inspirer that way.
Check the App Store there amy be an updated version, or something that does the the same things.
