Restoring From Time Machine BU to Remote Disk
I had OS 10.6.8 installed on a remote drive that I used frequently so that I could use programs not supported by later versions of Mac OS. That drive crashed and I couldn't repair it. Fortunately I have it backed up using Time Machine on another drive. I bought a new drive and formatted it using disk utility. I am trying to restore the OS 10.6.8 from the backup drive to the new drive but I can't figure out how to do it. Any help would be appreciated.
That's one of Time Machine's short comings. Do you happen to have either the OS 10.6.8 DVD, or an installation file for OS 10.6.8? If you do, then you can be "saved".
