- Nov 30, 2017
Hi All
I have a dilemma, hope you can help!
I spilt a little water on my macbook pro 2 weeks ago. Everything works fine apart from a few keys. I have connected a bluetooth keyboard and as far as I can tell the only damage is a few keyboard keys. One being the power button.
I have purchased a replacement keyboard which I plan to fit myself.
What I am worried about is.. the power button. Right now I'm not shutting down the machine, simply closing the lid. If it shuts down I don't think I'll be bale to power it up as the power button is affected and doesn't respond. From sleep I can press any key or the touchpad and it wakes.
If it shuts down is there a way to power up the pro without the power button? Maybe underneath? I dont know. I'm worried if I start taking things apart it won't 'sleep' it will shut down and I wont be able to turn it back on! If for instance the new keyboard for some reason doesnt work.. I dont know, I'm just thinking worse case scenario.
So I'm a bit stuck.. what to do! Risk it and fit the new keyboard or continue with the external keyboard. If I know theres a way to turn it back on without the power button all is good but I just dont know
Any advice is greatly appreciated!
Thanks so much
Thanks so much
