Problem with Mac Help Viewer
I am a recent Mac convert and I was trying to use the Mac Help and the search and links on the first page don't seem to work. I tried the other help files for Safari and what not and they seem to work fine. I pulled up the Console to see if I could figure anything out and this is what is says when I click on any of the links on the Mac Help.
2005-12-22 17:34:29.143 Help Viewer[210] Uncaught exception - *** End of archive encountered prematurely at 400
2005-12-22 17:34:29.143 Help Viewer[210] *** Attempt to remove unrecognized exception handler 0xbfffdd20
I tried rebooting and it still doesn't work, I'm not sure what to do. Any help would be much appreciated.
Thanks
Hi there and welcome !
We've all been on holiday !
Are you still having problems ? If so what version of OS X are you using ?
Regards
I've gotten a little further but not much. I got some help from another site that had me delete some files
~/Library/Preferences/
com.apple.helpviewer.plist
com.apple.help.plist
and
~/Library/Caches/com.apple.helpui/
After doing that I was able to get any of the links on the first page of Mac OS Help but once there none of the links in the sub categories worked. If I quit the help program then I am back to where I began and can't get past the first page without removing those files.
I am using OSX v10.4.3
Hope you had a Merry Christmas, have a good new year.
Apologies again, and Happy New Year !
First try and create a new user !
See if the mac help viewer works in that.
Can I just check, did you delete the directory ~/Library/Caches/com.apple.helpui/
That one normally works ;-)
Let me know how you get on with the new user account...it may be time for an Archive and Install...this sometimes fixes the relevant problems a lot quicker.
HI , having the exact same problem running OS X 10.4.3
I tried the above solutions and still the links after the first page don't respond. Other apps seem fine when using help viewer..
Any solutions yet?
Hi Max63126 and welcome !
So if I have understood correctly...
...all the links in the image below work, but once you have clicked on any of them the links on the next pages don't work ?
Also can you both open Help Viewer and then go to the about "Help Viewer" in the menu bar and let me know what version you have ?
hello to all,
I'm having the exactly the same problem running OS X 10.4.3
new powebook g4
I already did all sugestions above
no result
Hi there bimbachi and welcome !
what version is your Help Viewer ? (and the bit in brackets)
You are correct on both things.
That was a directory that I deleted
and...
the links on the image you posted work, but once on any next page they don't. That is only right after those files/directory are deleted. If I quit help and open it back up I can't even get past the first page again.
My help viewer version is. 3.0.0 (144.1)
Hi aaroc357
a few more things to try...
These are in no order.
1) Boot from your OS X Install CD/DVD and run the Disk Utility to repair the disk and permissions.
Then reboot and try again.
2) Download Pacifist and re-install the Help Viewer Application from your install DVD.
(if you go down this route I'll give you a couple of screengrabs to help along the way)
Same version here, Version 3.0.0 (144.1) And today when I tried to open it, I didn't even get to the first page (the one you posted Ric) like i did before.
Today it's blank! Tiger 10.4.3 Imac G5
hi,
my help version is 3.0.0 (144.1) and loged as new user help works?
I went through all cleaning again
Cleaning cache - solved problem
Thank you all
And specially Ric
Hi all,
Just a quick thank you to everyone who contributed to this thread: I had similar "Help Viewer" problems (where I couldn't view the "TextEdit Help", neither from "TextEdit > Help > TextEdit Help" nor from "Help Viewer > Library > TextEdit Help")... removing the "~/Library/Caches/com.apple.helpui/" cache directory solved the problem for me.
Regards,
pvandenberk
PS - I got slightly different error messages in the console; I've copied them below so that other's can find this most useful thread through their favourite search engine:
2006-02-01 10:03:17.375 Help Viewer[18964] *** NSRunLoop ignoring exception '*** End of archive encountered prematurely at 399' that raised during posting of delayed perform with target 37e260 and selector '_setupTOC'
2006-02-01 10:03:21.370 Help Viewer[18964] *** End of archive encountered prematurely at 399
Glad you got it working.
Thanks for the error post, I'm sure Google will pick it ! (It seems to be my friend at the minute ;-))
