problem opening Mac applications
When i click on Safari or mail and other mac applications (mac) they appear on screen momentarily and then quit.Any ideas?
Peter
Hello Peter and Welcome!!
It sounds like some disk permissions are bad. Let's try repairing those and see what happens. Goto your applications folder --> Utilities --> Disk Utility --> make sure the First Aid tab is selected. Select your Macintosh HD drive and click Repair Disk Permissions. After that's done, restart your computer then try opening those programs and see if the problem persists. Let us know how this works out for you!!!
Searay
Unfortunately this has not worked.Mac seems to thik everything is in order.Any other options?
Regards Peter
Hi there Peter and welcome !
Can you create a new user account and see if the Apps work in that ?
