Please help
Hello, my macbook pro is with PROBEM.
Very slow internet connection
IT is cut every 5 or 10 minutes.I must to restart to navegate again . In this moment in the trash basquet appears files.....named. "Recovered files" and into this file was other file called " wkresources".
the only thing that did was crack the MacKeepe.......r, and it all started.
Jaime Errázuriz A.
E&W LTDA.
Delete, Remove and Kill MacKeeper!!!
Don't worry about "Recovered files" they are just temporary files the Mac is in the process of deleting, but will give you a chance to check. These will often appear after an iWork App is quit without saving the document you were working on.
cross post - let try and keep this in one thread!
Thaks,I think that any malware are in my MacBook yet.
Still the Internet connection are very inestable , the only solution to fix is . And start other applications....
My mac are posses ...
Do you know any clean for troyans
Again , many thanks
https://www.mac-help.com/showthread.php?t=11955
No, I don't think you have a Trojan or Malware. You have install MacKeeper that will cause the problems you have. Get rid of that, before trying to fix anything else.
I'm deleted mackeeper and the problems still running . The first thing that I doing was , kill mackeeper
All my description problem , was after kill mac keeper
That is the razon that I think that I have a troyan...
