- Aug 22, 2008
Hi all,
I would appreciate any feedback you can provide. I have an ibook G4, and it has been very sluggish lately. Recently, every time I log on, it did not progress past the blue background screen. I did a PRAM reset, PMU reset, disk utility, Apple hardware test, and nothing changed or came up (in terms of hardware failures). I decided to do a clean reinstall with my install cd's. The thing is, AFTER the install CD progress bar was finished, an error came up and said that there were errors and I needed to reboot. After doing so and going back into the install procedure, my destination drive was no longer there! I try and reboot from the cd, but nothing changes. Anyone know how I can fix this? Any help would be appreciated.
HJ
HJ
