Low on memory
I recently started getting the Message "Your computer is low on memory. to free up some memory please close a few applications" Closing all applications except Safari makes no difference. What do I need to do?
Which exact model of mac do you have ?
How much RAM is installed ?
Which version of OS X/macOS ?
What software are you using ?
Desktop 21.5 inch 1TB
MacOSBig Sur Version 11.4
3.8GHz Quad-Dore Intel Cor13
16 GB 2400 MHz DDR4
Graphics Radeon Pro555X 2GB
hi Lufbrarunner,
Here is a snapshot of my Activity Monitor, this is the first time I have come across it!
There appears to be several applications taking a lot of time:
Suggestd 11.22.87
Safari 34:15.25
Finder 9:49.26
Creative Cloud. 8:03.41
Bird 22:10.65
Adobe CEF Helper (Renderer). 11.02.93
Adobe CEF Helper (GPU). 14:45.68
1010764094986606144. 35:07.26
I am unable to comment on any of them.
Thanks for being of assistance
  • 2021.06.07 @16.45.Activity Monitor.pdf
