- Feb 27, 2011
Should be an easy one.
Need to recover iTunes from a backup. (Not the music, that's all OK) When I just copy the app across from the backup, it wont open, gives me the following error:
"The iTunes application could not be opened. A required iTunes component is not installed. (-42404)"
MacOS is 10.4.11; PPC G5; version of iTunes is the last one that works for MacOS 10.4.
I'm assuming I need some preferences or library catalog file or something.... Any ideas?
Thanks
ihamp
Thanks
ihamp
