Ric said:
Let it send the report, it won't do any harm.
Does iTunes load/work without the iPod loaded?
I am right in thinking that before you ran fsck, iTunes was loading correctly - but only when you placed the iPod into the dock/connected to the Mac and allowed iTunes to load automatically.
...the problem was with clicking on iTunes in the dock?
...and now it won't work either way?
Whilst doing all this fault finding the iPod should not be connected to the Mac until we are sure that iTunes itself is working.
If you log out of your account and log into a different account, does iTunes work. (without the iPod plugged in!)
I think i have found the problem.
I tried to remove the firewire cable but the white casing on the connector came off and it's jammed in there so..
I'd just removed my ipod from it's dock loaded itunes and it came up instantly
I logged out switched to my sisters account which she reported problems w. itunes loading up and all was fine with itunes on her behalf so *goes back to my account*
So I loaded up iTunes again and all is well which I then quit then reload *repeated 10 times* and it works
Right i pop my iPod back into its dock and iTunes enexpectedly quits
so i load iTunes up again and it quits while iPod is connected
So I took my iPod out and reloaded iTunes *comes up*
(My conclusion) my iPod has been naughty and there is something wrong with it i had 2 files saved mpeg onto it which i'v deleted now
but, i turn my ipod on and all my songs have gone!
it's been wiped but i look into the about on it and it says ipod capacity 37.2 available 35.8 GB
Are my songs still on it?
And what should i do with the iPod?
Can i wipe it clean without using iTunes?
Thanks
Danny
