iTunes help ...
So most of m life I've been using winamp, but with my mac came iTunes and I kinda like it, but theres just a couple of features I miss and I'm wondering if it's just not possible with iTunes or I just can't figure out how ...
With winamp I could have a playlist in a seperate window from the library and drag and drop music into it. Isn't that possible with iTunes?
Also when playing a playlist you could rightclick a trakc and 'put in queue' so it would be played after the current song without permanently rearranging the playlist ...
Those features made it easy to listen to music at a small party where everyone could quickly go up to the computer and put a couple of songs from the library into the playlist, so is there any way to do this?
Double-click on the Playlists Icon in the Source column to launch that Playlist in it's own window. You can do this with as many Playlists as you like. ;)
I may have misunderstood your aim, but once you have the playlist compiled, you can right/control-click a song and have it play after the current track finishes. I don't think you can queue more than one track though.
Hope this helps ;)
