imac 27" 2010 a1312 power supply good or bad?/
hi guys i have a 2010 a1312 imac 27" and its dead.. i opened it up and tested the PS and i get 12v on the 4th pin on the right from bottom and 4v on couple pins about that.. no other readings BUT those 2 readings fluctuate from 1v to 12v and from 0v to 4v ?? bad ps or is that normal? thanks guys
It sounds like a bad power supply, but I am not trained/experienced in component-level testing. Apple doesn't publish those specs either, so it would be hard to determine if that is the cause.
Sorry,
