Help! Unable to open iMovie
My Mac version is OS X 10.9.5.
iMovie version 10.0.5
Unable to open, only get blank screen!
Use iMovie regularly.
Only way I can open iMovie is to hold down option key while opening the software. Then File-Open Library. iMovie then opens but freezes when I try to do anything. This happens every time.
iMovie will not open on its own as it has done for past few years.
Tried reinstalling but I get the same problem!
Plus not all my projects will open. Although the clips seem to be in iMovie Library?
I have important video ready to edit that I can't access.
I can use older versions of iMovie but not this version which I require.
What do I need to do?
Thank you very much
-How much free space is left on your hard drive?
-Did you have a recent power surge or have to force power off your Mac when iMovie was open?
