help,Internet Connect
I have made a big mistake :( I have deleted from Application, Internet Connect. What I have to do to reinstall Internet Connect? Can be downloaded separately? Pls help
:confused:
Hi there and welcome,
you have two choices you can either insert your System Disk and do an Archive and Install, this will will put a fresh System back on your Mac, or you can download Pacifist, this allows you to reload specific parts only from the OS X install disks.
