Help-Apple ID
Oops. I have a doc file that has password hints in it.. I guess I made the hint too cryptic and I'm unable to do any app, etc updates on my Apple products.
I've tried a few iterations.. but.. nada.
Seems there used to be something that popped up like "forgot" and it would send an update to the mailbox on file. This isn't happening with my iPhone.
Help???
Thanks, Bill
I'm a bit confused … are you using the iPhone to access a website & have forgotten your password and can't find the "forgot my password" link?
Which website?
No sir.. I'm guessing I didn't do a good job of explaining. My iPhone notified me of a few app updates. I can't update w/o my Apple ID. My brain is leaking.. but, IIRC, there are times when I need that Apple ID for the MAC as well.
The "forgot" above had to do with resetting that Apple ID if you couldn't remember the password. Hope that helps clarify.
It's all about the Apple ID... no websites involved.
