Hard Drive Problem - help!
The story goes like this:
I went upstairs while talking with my friend on AIM. When i came back downstairs, my macbook (160gb, black, 2gb, core duo) was frozen. When i turned it back on, the folder missing system file icon came up. THEN my uncle advised me to format the harddrive (i had nothing important on it anyways). When i try to install Leopard back on it, "an unknown error" occurs. Meanwhile, when i try to repair the disk with disk utility, it errors with the "could not unmount disk". Anyone know whats wrong? If you need more info just ask and I'll give you and answer and hopefully you can help.
Thanks
Hi Diego and Welcome !
have you managed to format the drive ?
