garageband issue (ibook g4 os x 10.3.9)
The Instrument Library is invalid. GarageBand expects a valid Instrument Library folder in /Library/Application Support/GarageBand.
Please choose a valid Instrument Library folder or quit and re-install GarageBand
this is what i am getting when trying to open garageband. i have the ilife '05 dvd. this is after installation. the other programs in ilife seem to function fine. only garageband is giving me trouble. i deleted garageband and reinstalled the program and it is still giving me problems. can you help please? thanks...
Hi there and welcome,
Have you had a look in that location to see if 'that' folder has been installed ?
First thing to try...delete GarageBands preference file...
/Library/Preferences/com.apple.garageband.plist
Then try opening GarageBand again, if that doesn't work then...
...you could delete GarageBand again...then use Disk Utility to Repair Permissions.
Then reinstall GarageBand, does it work ?
Let us know...
thank you very much. this fixed the problem. i appreciate your quick response. this forum will definitely go on the favorites tab.
david.
