- Oct 20, 2007
Dear Experts...
I'll try and describe my problem as good as I can but I'm sorry if my english is a little poor!
First og all my specs:
I'm running a 4 month old MacBook Pro with Mac OS X 10.4.10
Suddenly last night my Finder started to turn on and off all the time (the interval is approximately 5 seconds) and all the folders incl. the Hardisk-icon disappeared from my desktop.
I've tried to restart a dozen of times and the problem is still there.
At one time Finder stopped "restarting" over and over again and I had a chance to go to my application folder and run the disktools. When I run "control disk" it comes with an error I'll try to translate:
Error: The assignment hereunder reported an error
1 HFS-unit controlled
Units has to be repaired
But Disktools wouldn't let me click "repair disk"
I've tried to open with shift down, and I've also tried to restart in consol-mode (apple-S) and run a fsck -fy. This says that: "System HD seems to be okay"
I've also tried to run the disktools in OnyX ... this also says that disks are okay.
I can see on this Forum, that I'm not the first to encounter this problem and they've been recommended to remove the com.apple.Finder.plist-file. I've tried this to without any luck...!
I've furthermore just found out that if i close the screen down, so the Mac goes to sleep (don't know if that's the correct term) and I open the screen again, then 1 out of 3 times this makes Finder stop restarting all the time ... this is really strange!!!
I'm running out of ideas
What shall I do???
By the way I'm in France for the next two months and I haven't brought my installation-disk, so I can't use that.
Please, please, please help me...!!!
