External hard drive problem
Hi
I have an NTFS external hard drive, which I bought to use with my PC.
I have connected it up to my intel iMac, and it recognised it straight away. However, it will only let me 'read' files, not 'write' files. So basically I can't save any work done on my mac to it, which makes it pretty useless.
Normally you can change permissions to a folder/file by going apple + i, but when I try this it just has a message saying 'you can only read files'.
I wondered if anyone had any advise on how I can sort this problem out?
Thanks
hmm write only yes ?
hve you tried formatting it yet to ms dos compatability ? ( fat )
that usually seems to sort the little buggers out
Hi there,
as bluekatt says...
and as we said in post 8 of this thread...https://www.mac-help.com/forums/showthread.php?t=484 ;-)
Just open up Disk Utility select the drive and go to erase and select the MS-DOS file system as below...
This will erase the drive and change the filesystem to FAT32, which you can then read/write on both systems.
Go
From what I remember, OS X may be able to read NTFS disks, but it cannot write to them. The only Windows formatting it plays nice with is FAT32.
Hi
I have read this but when i try to do to an erase all options are greyed out. Can anyone advise. Thanks
