Hi there!
I am not sure if this is the right place, or if i'm running Panther or not. It doesn't really say in the "About" window. I didn't install the system and missed it when they did it for us.
Currently, I'm working in an office with 1 Mac OS X 10.4.7 server and several Mac OS 9 classic workstations.
The problem I'm having is a bit wierd, so I'll try to explain it the best I can.
The server has an internal HD volume called "Shares." It contains a few folders that we use for our stuff: Ads, Art, Archives, etc.
We needed some extra space so we ordered 2 more HDs and they came as externals and they're connected with FW800.
Workgroup Manager has the share points setup for our Internal HD fine, we never had a problem copying files on the Mac OS9 Clients back and forth between the folders in the Shares volume.
When we got the new External Drives and created the new share points, we noticed a peculiar problem.
To back up a bit, all our Mac OS 9 clients all connect to the Server's volumes as Guest. We always have over the years, it's just easier that way I guess.
When we went into Chooser and chose the new External Drives' share points (Archives 1 and Archives 2), they appeared fine on our Mac OS 9 workstations.
The problem is that we're unable to copy files from External/Archives1 > Internal/Shares/Ads. Internal/Shares/Ads > External/Archives1 doesn't work either.
External1/Archives1 > External2/Archives2 doesn't work too.
The errors we get are "Type -50" or "cannot be written, because the file cannot be found".
I've clicked on "Ignore permissions" on the Info window for the External drives but that didn't seem to help.
My only theory is that it's the Guest permissions that are causing the problem.
I tried for fun logging in on the Mac OS 9 workstation in Chooser as one the admin logins on the server. The admin login was able to choose the hard drives and not the share points. But... I could copy from one drive to another with no problem.
I'm not sure how to fix this so our Mac OS 9 workstations can copy properly without getting errors. It's just annoying more than anything. We have to take the folder and copy it to the desktop first and then copy to the other internal volume or vice versa.
Thanks
I hope someone out there is experienced in Mac servers >.<
Thanks
