Changing 30fps to 25fps on mini iPad
Hello out there. Can anyone tell me if it's possible to change the frames per second (fps) recording rate from 30fps to 25fps on a mini iPad ver 8.1.3. I want to add video footage from it to Lightworks for editing with other footage I shot at 25fps. I don't want to change the iPad footage from 30fps to 25fps, just the recording setting for future work. If it's not possible to do this I'll leave it alone.
Thanks in advance for any advice you might have.
You cannot change the frame rate for video on the iPads to 25fps. However, you may be able to use a third-party application to convert your current footage from 30fps to 25fps to match your other clips.
Thanks for that Cory. I'll leave it alone. I couldn't be bothered to start converting.
Thanks for your help anyway.
Regards
P
