Audio Playback Control
Hey
I want to be able to play whatever is open in GarageBand, iTunes and QuickTime at the same time. I've just started researching AppleScript, and it seems like I probably have to tell each of these applications to use the command to play (as if the space bar is being hit for example in all three of these programs) when the script is run.
Can anyone help me out?
Thanks
Niv
Hi there Niv and welcome...
You can do this via AppleScript using GUI Scripting...
activate application "QuickTime Player"
tell application "System Events"
tell process "QuickTime Player"
-- GUI Scripting statements:
keystroke space
end tell
end tell
activate application "GarageBand"
tell process "GarageBand"
keystroke space
end tell
end tell
activate application "iTunes"
tell process "iTunes"
keystroke space
end tell
end tell
For this script to run you need GUI Scripting to be turned on.
