Experiencing AirPlay disconnecting or freezing can be frustrating. Here's how to address this issue efficiently.
By implementing these solutions, you're on your way to a smoother and more stable AirPlay experience.
How to Stop Airplay from Randomly Stopping:
1. Ensure AirPlay Devices are on the Same Network
- On your Apple TV, navigate to Settings.
- Select "AirPlay" and then choose "AirPlay" again.
- Ensure that the setting is adjusted to "Only work with devices on the same network."
2. Modify Apple TV Security Settings
- Go to the "Settings" on your Apple TV.
- Choose "AirPlay and HomeKit."
- Select "Allow Access" and then choose "Anyone on the Same Network" or "Require Password" for extra security.
3. Restart Devices
- Turn off your Apple TV and any device (iPhone, iPad, Mac) you're trying to AirPlay from.
- Wait for a couple of minutes and then turn them back on.
- Attempt to use AirPlay again.
4. Update All Devices
- On iOS devices, go to Settings > General > Software Update. Install any available updates.
- On a Mac, open the Apple menu > About This Mac > Software Update.
- For Apple TV, go to Settings > System > Software Updates and select "Update Software."
5. Check Wi-Fi Connection
- Make sure all devices are connected to the same Wi-Fi network.
- Consider using a 5GHz Wi-Fi network for better performance and less interference.
- Restart your Wi-Fi router by unplugging it for a minute and plugging it back in.
6. Use Ethernet Connection
- Connect your Apple TV to your router using an Ethernet cable.
- Ensure your other device (Mac or iOS device) has a strong Wi-Fi signal from the same network.
