administrator name and password problem
for some reason leopard has changed my administator name and password because when i try to type it in it claims it is incorrect here are some screen shots
/Users/guygrieve/Desktop/Picture 1.png/Users/guygrieve/Desktop/Picture 2.png/Users/guygrieve/Desktop/Picture 3.png/Users/guygrieve/Desktop/Picture 4.png
here arre the screen shots
Start using the Leopard Install Disk. Select English for your language and then go to the Utilities Menu at the top. From there select Reset Password, select your hard drive and hit OK. From there select a username and type in a new password. This is the easiest and least time consuming way to fix password problems. Good luck.
So you boot from the cd and are asked for your password ? Have you tried booting and holding down the "c" key ?
