2007 Macbook-Compatible Monitor
MNL
Any ideas how to find a monitor that will actually work with my 2007 macbook (2.2GHz Intel Core 2 Duo (13-inch White) MB062LL/B )? Reviews of the nicer models report that they don't work well with the older macbooks. And the cheaper monitors? Aren't too many reviews of those at all.
What model should I get?!
Thanks.
MNL
-What kind of budget?
-What size are you looking at?
-Can you give us the make/model of some that you are considering?
That particular MacBook has a Mini-DVI port and can support resolutions up to 1920 x 1200. It can also support VGA monitors with an adapter.
