When you encounter the "zsh: permission denied" error on your Mac, it's typically a sign that there's an issue with executing commands or accessing certain files. This guide will walk you through four practical methods to swiftly resolve this problem.
By following these methods, users can effectively tackle the "zsh: permission denied" error on Mac, addressing common underlying causes such as incorrect commands, insufficient permissions, and restricted access issues.
How to Fix Zsh: Permission Denied error on Mac:
1. Verify and Correct the Command
- Open Terminal on your Mac by going to Applications > Utilities > Terminal.
- Carefully type the command you were trying to execute, ensuring there are no typos or syntax errors.
- Press Enter to execute the corrected command.
2. Check and Adjust File Permissions
- Launch Terminal from Applications > Utilities.
- Enter ls -l, followed by a space, but don't press Enter yet.
- Drag and drop the file you're having issues with from Finder to the Terminal window to automatically input its path.
- Press Enter. Terminal will display the file's permissions.
- If necessary permissions are missing, change them by using the chmod command followed by the appropriate permissions level and the file's path.
3. Grant Full Disk Access to Terminal
- Click on the Apple logo at the top left corner of your screen and select System Preferences.
- Navigate to Security & Privacy, then select the Privacy tab.
- Scroll down and choose Full Disk Access from the list on the left.
- Click the lock icon at the bottom left to make changes (you might need to enter your admin password).
- Click the plus (+) button, find Terminal in the Applications folder, and add it.
- Close and reopen Terminal for the changes to take effect.
4. Change the Directory Ownership
- Open Terminal.
- Type sudo chown -R $(whoami), add a space, and then drag the folder or file from Finder to the Terminal window to automatically fill in the path.
- Press Enter and input your password when prompted.
