Why is my Macbook Pro 2012 retina all of a sudden overheating and clocking down?
Hi there,
My macbook pro 2012 retina is running at a steady 105 degrees pretty much whenever I do anything. It's a 2.3 GHz Intel Core i7 with 8GB ram. I'm regularly using a second monitor via HDMI and an audio interface using thunderbolt to firewire 400. A few months ago I opened the computer up, replaced one fan, and cleaned all the dust out with compressed air. I also put new heat sink paste on the CPU but I fear I may have put far too much. Could this be enough to cause these problems?
Whenever I open a new program, click on a new youtube video, open a new tab even, it hikes the temp up to 105 degrees Celcius, and clocks the CPU down to 0.83 GHz and makes the computer next to unusable until it cools back down. This is with very moderate ram usage in activity monitor but my CPU load sky rockets. Kernel (in activity monitor) starts to use upwards of 200% CPU power. I can also hear my fans kicking in like crazy.
I'm getting this temp info from the Intel Power Gadget. which says the Power usage, as well as Frequency and Temperature.
In the attached file you can see the moment I click on a youtube video and it dips down to 0.83GHz. The temp didn't quite hit 105 because I literally have a gel ice pack underneath my laptop.
Any ideas of things I could try?
Many thanks,
Alex
I can't imagine why excessive heatsink paste could be the problem unless it spread over the edges of the CPU.
Considering you have a 2012 Retina MBP, I'm curious why you haven't installed more RAM? I have the non-Retina 2012 MBP, and it had 8GB RAM when I bought it. I thought it ran a little warm compared to my previous laptop, but after I upgraded to 16GB a few days later, it seemed to run much cooler.
Not sure what programs you're running, but it doesn't sound like you're placing an undue load on your CPU unless you're simply doing too many things at once. However, I never seemed to bump into that ceiling even with only 8GB of memory. And I would have Photoshop, Illustrator and Premiere all running at once.
Thanks for your reply.
I've attached a screenshot of the RAM usage from activity monitor. I don't think ram is the problem. I have been thinking of upgrading though. But I other than updating a few very basic programs (browsers, spotify, etc.) I haven't actually installed anything new and RAM or CPU intensive.
There is actually a chance the heatsink paste may have come off the edge of the CPU after I put it back together. I just ordered the appropriate macbook screwdrivers to open it up and have a look. Can you explain why that would be an issue? I've also read that simply too much heatsink paste can have the opposite effect.
Oh, I should mention I'm only running Mavericks because of a few audio programs that can't run on newer OSs.
The heatsink paste acts much like the heat shields on the old Mercury/Gemini/Apollo and shuttle spacecrafts. It's an ablative substance that absorbs and quickly dissipates heat. It any excessive paste is able to contact the surface of the motherboard, it can dissipate that excess heat detrimentally.
By the way, OWC offers an excellent toolkit which is perfect for tinkering with MacBooks for about $15. Well worth the cost. In a pinch, take your MBP with you to a good hardware store and someone there should be able to provide you with sufficiently small screwdrivers for your purpose.
Thanks for the info. I've already bought set of screwdrivers for about that price which should arrive next week. I wonder if the quality of paste has anything to do with it? I bought a small syringe full at a local computer shop called Arctic Silver 5. It was all they had.
I really couldn't address the issue of the quality of the paste you used. But I would have to assume that it's got to be decent stuff since it certainly wouldn't be in anyone's best interest to sell you an inferior product, particularly if they value their customers and hope to stay in business!
Depending on the paste, you may need a solvent in order to remove the old gunk. Don't use fingernail polish remover, even though I've seen people recommend it before. Straight acetone is ideal, but you have to buy a quart of it at most hardware stores. Then again, acetone is a very, very handy solvent for tons of other purposes. Use Q-tips when applying it. And since acetone evaporates so rapidly, don't over-soak your swabs. Use multiple swabs in multiple applications in order to do the job. Be patient. Go slow. Take your time.
One other small bit of unsolicited advice: when putting the bottom back on your MBP, resist the temptation of tightening those minuscule little screws too much. You risk gouging out the sharp edges of the screws, making them difficult (if not impossible) to remove should you ever need access to the innards of your machine again. Just get them snug. But I'd suggest you check them again in a day or so if you tote your laptop about with you much in case they've loosened. I did lose a single screw once, but it wasn't the end of the world. I managed to get a free replacement sent to me by my favorite "Mac stuff gettin' place," OWC (and, no, I don't get paid for tooting their horn! I just love doing business with them).
Thanks a lot for the advice there! Yes I've opened up my macbook many times. I just don't have the screwdriver myself anymore. Last time I replaced the heatsink paste I used 90% ethanol and a bit of toilet paper and it worked just fine, but I like the idea of Q-tips.
Ethanol is good. Just make certain it IS ethanol. I'd still recommend acetone, however.
In a previous life I worked in printing and publishing, and had to come up with a way for our pressmen to concoct a dampening "fountain" solution for use in offset printing. Due to our particular circumstances with fluctuating humidity, we needed a way to reduce the surface tension of that solution, which was 95% water, 3% glycols and 2% inert ingredients.
An unscrupulous supplier sold us methanol (wood alcohol) instead. While somewhat similar chemically, the difference was crucial. It didn't produce the desired results. Moreover, I don't recommend that anyone work anywhere in the vicinity of methanol fumes without robust ventilation. That's the form of alcohol which blinded and killed so many people back during Prohibition because of either improper distilling or the fact the bootleggers simply didn't care.
At any rate, also avoid Isopropyl alcohol (the rubbing kind). Most of it is a 70% solution. You can get a 90% concentration for pennies more, but I'd avoid it because it still contains an oily type of "inert" ingredient which is often detrimental for use in electronics applications.
Oh very interesting. I think what I used actually WAS or at least may have been somewhere between 90-99% rubbing alcohol. I hope isn't the problem. It evaporated quickly though and I waited until it did before applying the new paste. I'll see if I can find the bottle but I've moved a few times since then so it's unlikely.
And yes I know what you mean about methanol, I had a cousin who temporarily went completely blind until his liver processed it by inhaling too much of it by accident.
Isopropyl alcohol does evaporate quickly. However, it does leave a residue behind which isn't visible to the naked eye. 70% is a much, much worse offender in this regard, but the 90% variety does as well.
almix12,
It looks like we are neighbors! I live about 25 miles south of Seattle. How far from Vancouver are you?
Allen Davis is an excellent source of information! And his knowledge on all this "alcohol" stuff is priceless! I hope you get your issue resolved.
Quite near Vancouver, one boat away on Vancouver Island.
I was wondering, what sort of store would have proper ethanol (not rubbing alcohol) suitable to remove the paste? A drug store? Or a computer store?
Can understand the (possible) increases in temperature, but the higher CPU speed is perplexing! And it is not a small amount that it is "over clocked": anywhere from 20% to 30%! Not sure if that is good or bad. Interestingly, the Download speed I have from Xfinity, 250 Mbps, is (at times) somewhat significantly above that, as I have seen it as high as 300 Mbps (via the site www,speedtest.net)! In fact, I just did it, and it is at 284.28 Mbps. I realize it is not the same situation as yours, but not sure why the increase in speed (but obviously I am pleased, as I have always had "I feel the need, the need for speed").
Thanks for the response. As to your mysterious speed increases, some ISPs actually have (and some actually advertise) an initial "power boost". Where I'm not sure as to the mechanism, it basically gives you some extra speed at the start of any download, or for example, loading a website.
But this is unrelated to CPU.
Also, it's actually a slight decrease in temperature which is positive.
A slight decrease in temperature is good! How is your Mac running?
You also stated above "Oh, I should mention I'm only running Mavericks because of a few audio programs that can't run on newer OSs.". Any chance that either there are newer versions of those programs, or that other ones exist that have the same functionality? The reason I ask that is (maybe this is a "shot in the dark") upgrading (via a clean, fresh, "virgin" installation of whatever newer Mac OS you might want to get to) might help in this situation. Again, though, just a guess on my part, as you have identified issues with some of the components inside your Mac. Of course, if you do "move" to a newer version of the Mac OS, besides doing the necessary preparations, you'll need to insure that any other third-party software you are using is compatible with that newer Mac OS. This site can hep with that:
https://roaringapps.com/apps
By the way, that site could help you determine if those few audio apps you use have upgrades available for the various versions of the Mac OS.
As for my increase in download speed over what is "advertised" by Comcast, it does vary when I use that site www.speedtest.net. One thing is which server it is measuring it from. (Just ran it again, and the download speed is 293.51 Mbps). Seems like the servers it is using are "located" in Seattle, which is about 25 miles north of where I live (give or take a few miles, depending on where in Seattle the server it is using is).
