Trouble with Vebatim USB Drive Store n Go
ok, I have bought a Verbatim USB DRIVE for back-up. (My friend had one - and I thought that would work for me.
I got a 2 GB Store "n" Go and the package has the little MAC icon on it. So I thought I was good to go.
The directions only say that "It will automatically be recognized by your system. Insert the drive and click on the "Untitled" drive icon"
Unfortunately, I didn't get that untitled drive icon.
I only have access to 4 PDF files - one of which I can access in English and one .exe file which a Mac can't open . But no application anywhere.
I have done a search to see if that Drive might be somewhere on my computer, but alas, no luck.
AND - when I did a "get info" I was told it was a MS-DOS application.
OUCH.
Any ideas?
Hi there and welcome !
Is it a little 'thumb' drive ?
Is it not appearing on the Desktop ?
Try Finder Preferences-->Show Hard Drives on Desktop 'ticked'
If it's not that then...
Just plug it in and then go to Applications-->Utilities-->Disk Utility
and reformat the the drive as HFS Jounaled...
You should be okay then !
Ric:
By thumb, you mean the small 3" long probably an 1" wide, right?
I did the Frinder Prefs and it was identical to yours.
Ok, then I got to the Utilities, but can't find something there that says "Reformat"
(Can you tell I am really cautious about this!)
It says:
First Aid - Erase- Partition - RAID - Restore
Which is the right one?
Thank you for trying to help - I really appreciate it.
Brahmama
Hi there,
click on the 'erase' tab...
Then select Volume Format : Mac OS Extended (Journaled)
Then press the erase button.
This will reformat the Drive so everything on it will be lost, but it will now be a Mac format...
Is this what you want ?
Thanks, Vic,, this is what I needed to know.
I appreciate your help.
Brahmama
Brahmama said:
Ric:
It says:
Brahmama
